i got a 02 scrambler 500 i snorkeled it air box and belts ran fine put a new exhaust on it still ran fine upo and down drive way took it ridin and it didnt seem to have power and now it will idle all day long but when you throttle up it wants to cut out and backfire bad..i cleaned the carb checked alll that out new plug..i heard it needs jetted but it didnt do it until all a sudden idk what it could be..any help
take your pull starter cover off and remove the nut that holds the flywheel on and the washer and look to see if the key has been sheered if it is moved just a lil bit this could cause ignition timing probs i just experianced this with one i purchased and just got running simple fix if thats what it is
Nikkih
Jet up the main.
