I'm looking at doing an epi sport/utility clutch kit in my 500. I would go with a more custom kit but for under a 100 for a complete (weights springs helix) brand new I think I'll be happy. What is the stock engagement vs epi sport utility.
I am your basic rider. Mainly trails pretty hard on and off the throttle. Not much of a mudder but play once in a while and stock tires. I have a white brothers pipe and k&n filter. I want more bottom end power to help launch and wheelie a little better.
Would I be better off with just replacing the primary and secondary springs.
Any down side of clutch kits other than higher engagements?
Thanks guys!!
Not all kits have higher engagement. Most of the epi stuff I've installed and run has bumped engagement 300-500 rpm over stock. For the money you can get it for its worth a shot.
Riden, I thought I read a post about using a sportsman secondary on the scrambler? Can't seem to find it now. What advantages are gained?
Depends on the secondary. There are button and roller style. Advantages and disadvantages to both. The EBS machines use the roller secondary, NON-EBS use the button. Both work good in most cases.
