ive fixed the play in the steering DIY style but i cant seem to get rid of the up/down play. would the stearing post bearing from HPD solve this?
have you checked the bushing,bearing and bolts at the bottom of the steering stem
yes and once i tighten it up it makes the steering to tight. ive though about pulling the nut off and adding a couple washers to close the gap.
well i found a good and cheap fix.
i hit up my local ace hardware which stocks pretty much everything. i got 4 -7/8" machine bushings. they closed the gap and allow it to steer better. ill eventually rebuild the whole assembly but for this winter it will work fine.
