1 - 2 of 2 Posts
I have a 02 500 Magnum that has been sitting for close to two years. The problem is it's leaking gear lube from I believe the tranny, (middle on the right side) and also some where up front. Could the seals be dried up which is causing the slow leaking?
Also is there some kind of additive I can add to the gear lube to make the bad seals swell up or should I just take it to a shop? If I take it in, is this a major repair that'll cost alot? Other than this it starts right up and runs great.
I'd really appreciate the help anyone can give me!!!!
Thanks,
Jim
1 - 2 of 2 Posts
