1 - 8 of 8 Posts
Have a 07 Polaris 450 sportsman, only had it for 5 months. at 1st got 6 good weekend rides, then the buttons went on the secondary clutch, shop replaced buttons. got 3 weekend rides, secondary clutch un turned it's self into 2 pieces/wrecking the threads. rplced the clutch, 2 rides later buttons went again. fixed the buttons. 1st ride out secondary clutch (the brand new clutch) un threaded its self. BRAND NEW CLUTCH $500.00 IN PARTS. I was told by the shop dont ride up hills in high gear. So I did what they said, rode it like a 90 year old guy would ride, cuz I can't keep buying clutches. AND IT STILL ENDS UP IN TWO PIECES. HELP HELP
Welcome to the board!:fest30:
My qaud is the ONLY ONE in world, that has this problem? Hmmmmmm????? maybe I gotta go somewhere else to get some ideas?
is it missing that lockwasher on the mount bolt? weird how it keeps coming loose, also check transmission shaft for worn spots
Lockwasher/shaft......all good. Out of the factory it has a shim/washer between the clutch and transmission. Polaris shop told me I can use up to three of these shims. Making the belt ride more on the sping loaded side of the clutch.?.?
Would that shim be #14 in the pic and are you
using 3 shims when this happens?
Hello, I just had the exact same thing happen.. secondary clutch unscrewed itself, can I ask what you found out with yours?
1 - 8 of 8 Posts
