1 - 2 of 2 Posts
We have a sportsman 335, and on the secondary clutch, the bolt that goes in the middle continues to back out,we have put lock tight on it and torqued it at 30,and backed out again,after putting bolt in it will do good for little while then it backs out and it will not move,everyone we have talked to says they have never heard of this any suggestions what would cause this
Yep - never heard of it, but that is not the problem - the problem is deeper - the secondary clutch is on a splined shaft - my guess is the snap ring holding the clutch together has come off and it is now being held together with the bolt, which would cause the problem you describe, or the splines on the shaft or in the clutch have Brinelled away and the bolt is the only thing transmitting power from the secondary clutch to the transmission shaft.
1 - 2 of 2 Posts
