05 700 was riding in the snow floor boards were full of snow so maybe I didnt have the brake down far enough jerked shifter then it got lots of play in it and cant get any gears exept hi
did you look at it, does the little leaver thing on the transmision move or did the rod break? it's really not that complicated, take the 3 or 4 bolts off that shifter box and have a look inside.
I had the same exact thing happen to me yesterday. The heime??? joint on the high and reverse side of the linkage had broken at the transmission. Took the rod off welded it back together and I was back on the trail in 20 minutes.
Will the transmission shift out of high, or is the machine stuck in high?
