1 - 8 of 8 Posts
Looking for a set of shocks for my 2015 SP1000 Touring. It is my understanding that the Scrambler and Sportsman are the same chassis. I also assume that the touring is same as well?
I have found a good used set of Fox shocks that are off of a 2009/2010 Sportsman 850 and am looking to make sure that the fitment will be correct. It looks like there may have been changes for the later models.
Discussion Starter #2
830-27-013
This Item Fits the Following Applications:
2012-2012 Polaris Sportsman 850 HO XP, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
2012-2012 Polaris Sportsman 850 HO XP EPS, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
2012-2012 Polaris Sportsman 850 HO XP EPS Orange Madness LE, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
2012-2012 Polaris Sportsman 850 HO XP EPS Browning LE, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
2009-2011 Polaris Sportsman 850 EFI XP, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
2009-2011 Polaris Sportsman 850 EFI XP w/ EPS, Application: Front, Piggyback, Fitment Notes: Stock Shock Mount (Stock) A-Arms
830-27-018
This fits the later ones. I'm not sure what the physical differences are.
Longer frame, but I don't think that the suspension is changed is it?
Can't say for certain about the newer models, but the rear shocks/springs on my '07 X2 where a much larger/longer shock than on the regular sportsman. The front struts were the same as the other Sportsman machines. You should be able to just cross reference part numbers to see if they match up.
They shortened the rear shocks on the 2014 thru 2016 XP's.A little over an inch shorter.
Sent from my SGH-I547C using Tapatalk
if they were on a 2009/2010 sportsman, then they weren't stock as they didn't start putting Fox shocks on the Sportsman 850 until 2014 for their LE model. they did start selling a Fox shock kit in 2014 which is likely what they are. they fit every model year 850 so they will work on yours.
Product Specs:
Part #: 2879892
Item fits the following models:
TYPE YEAR MODEL OPTIONS
ATV 2015 SPORTSMAN 850 FOREST INTL
ATV 2015 SPORTSMAN 1000 XP
ATV 2015 SPORTSMAN 1000 TOURING
ATV 2015 SPORTSMAN 850 TOURING SP
ATV 2015 SPORTSMAN 850 SP
ATV 2014 SPORTSMAN 850 TOURING INTL
ATV 2014 SPORTSMAN 850 HO XP EPS
ATV 2014 SPORTSMAN 850 HO TOURING EPS
ATV 2014 SPORTSMAN 850 FOREST
ATV 2013 SPORTSMAN 850 XP
ATV 2013 SPORTSMAN 850 TOURING EPS INTL
ATV 2013 SPORTSMAN 850 HO XP EPS
ATV 2013 SPORTSMAN 850 HO TOURING EPS
ATV 2013 SPORTSMAN 850 FOREST
ATV 2012 SPORTSMAN 850 TOURING EPS
ATV 2012 SPORTSMAN 850 FOREST EFI 4X4
ATV 2012 SPORTSMAN 850 XP TOURING EPS INTL
ATV 2012 SPORTSMAN 850 XP EPS
ATV 2011 SPORTSMAN 850 XP EPS
ATV 2011 SPORTSMAN 850 X2
ATV 2011 SPORTSMAN 850 TOURING EPS INTL
ATV 2011 SPORTSMAN 850 FOREST
ATV 2009 SPORTSMAN 850 XP INTL
ATV 2009 SPORTSMAN 850 XP EPS INTL
ATV 2009 SPORTSMAN 850 XP EPS ALL OPTIONS
ATV 2009 SPORTSMAN 850 XP ALL OPTIONS
it is also worth noting that you'll need to pick up a different radiator hose as the models with Fox shocks require a different hose due to the shock resi being in the way. the correct part number for the hose is 5414505.
1 - 8 of 8 Posts
