Not mine, but Backwoods Armor is putting out some sick new lifts. This is an 8"
Actually the angles are not that bad. He states that the fronts are 34 degrees and the rears are at 36 degrees. Cobras, Gorillas, and turners axles are designed to run up to 40 degrees.How does he keep cv joints from snapping in that thing? That is some extreme angles!
Plug on bottom of air box on left side of bike broke off and i didn't know and hit a deep hole and it sucked the water into motor from throttle body and exhaust:banghead:What water issues did you have?
Are you running the frame supports I make. I have them in the scrambler 1000 aftermarket parts thread. I would think that lift has got to put some major stress on the frame that alot of guys are breaking with stock arms.Plug on bottom of air box on left side of bike broke off and i didn't know and hit a deep hole and it sucked the water into motor from throttle body and exhaust:banghead:What water issues did you have?
I have seen them before and am looking at getting the frame brace for engine along with the clutch cover piece.Are you running the frame supports I make. I have them in the scrambler 1000 aftermarket parts thread. I would think that lift has got to put some major stress on the frame that alot of guys are breaking with stock arms.Plug on bottom of air box on left side of bike broke off and i didn't know and hit a deep hole and it sucked the water into motor from throttle body and exhaust:banghead:What water issues did you have?
