Hi all, I have a 1996 xplorer 400 and I have to remove the right side cover that houses the water pump. I have the motor on the bench and the case loose and broke apart but I need to know about the center where the crank comes through the case. Is there just a oil seal on the crank? The case does not want to let go around the crankshaft. Should I just pry it apart or is there another way to get it to give? Thanks all.
Then it should just pop off once you get the retaining bolts out of it. But it is probably stuck on the gasket a bit and may take a bit of a smack from a soft hammer to pop it free.
