1 - 1 of 1 Posts
My propeller shaft is loose on both ends and vibrates at high speed. Typically is it the female shaft ends that wear or the male ends coming out of the transmission /differential, or both. I would like to know before I order a new shaft. Is this a commonly worn out part? My 04 sportsman only has around 1000 miles on it. For that matter both front drive shafts are sloppy as well. Can you get cheaper after market shafts? Thanks
1 - 1 of 1 Posts
