hello quad maniacs! New member first post. I have a 2012 500 ho . Need to know a little more of how a modded exhaust can help correct snorkel jetting issues. I haven't done my snork yet but want some more first hand knowledge from u guys, would exhaust mod make it run lean and would 2 1.5" intakes make it run rich, there by 'cancelling' each other out ? correct ? no? Let me know thanks
Welcome to the board!:med:
Carbs are tricky, and it seems almost none act the same. It is hard to say that you will be ok. There are many factors, like what size snorkel, what kind of tubing (different tubing, different restrictions), the length of your snorkel, and exact location of snorkel(how much air it is drawing in). Then you have different exhausts that also act differently. I say the best thing to do is to give it a try and see how it runs. If it doesn't run right then you know you need to rejet.
thanks people
