I bought a 2007 Polaris 800 Sportsman a couple of years ago. It came with a 52" Polaris plow, I don't see any other description on it. I don't know if the previous owner customized the push frame and I have been searching online for one that looks like it but can't seem to find any. The push bar (frame) goes all the way under the machine and plugs into the receiver, then you hook the winch cable on and lift the plow and a simple hook attaches to a rod on the front frame center. I can't find any installation manuals, it works fine but it almost seems like another support pin would line up with the front frame and I tried it by putting a ten inch long carriage bolt through but then it almost seemed like the plow wouldn't go down low enough.
Has anyone seen a set up like this?
