1 - 1 of 1 Posts
Just picked up a 2001 Scrambler 500 4x4. Any suggestions on a swing arm skid plate or is the factory guard good enough. It will be ridden in some rocky areas. Any way to disable the reverse button so you don't have to press it while backing up? Is the clutch the same as the Sportsman 500 ho?
What chain maintenence should be done? Just spray off with a water hose and use Polaris spray lubrication? Anything else I should be aware of specific to these machines?
Thanks for any replies.
1 - 1 of 1 Posts
