1 - 16 of 16 Posts
I did search but found nothing specific. I dont know about others but I have better luck using google search to find stuff on PATV but may be just me.
Anyway... 2012 Sportsman 800
Mainly semi- aggressive trail riding in MN/WI area. What is the best replacement plug?
NGK all the way!
I'd go with an NGK Iridium plug...... let me know how the swap goes. Maybe I'll attempt it too if it's not to much of a [email protected] to do! :D
I'll hop on the NGK train, they make a great plug
Discussion Starter · #6 ·
Discussion Starter · #7 ·
Discussion Starter · #9 ·
OK. Let me rephrase this. Of all of the NGK plugs listed as a which one would be the bes replacement for the champion plug for my machine/ location.
Sent from my MB886 using Tapatalk
I just picked up some NGK IX iridiums for my 500HO...I have not istalled it yet so cold outside....But a friend of mine with a 850 put in Denso iridiums and was very pleased with them...said it helped alot with cold starts an idles much smoother and no hesitation.
but from reading lots of post on forums i went with the NGK iridiums...
NGK Iridium IX® Spark Plugs
Advanced Auto had a NGK deal buy one plug an get other 50% off so I got 2 NGK's for my machine...one to install one for the bag incase of plug failure while riding...
cant beat NGK..most used plug in powersports...
The BKR7E (V-Power)
I recently bought a a vpower plug. The guy at the parts counter told me not to gap it. Told me it would ruin the electrode. Anyone heard of that?
I'd go with the BKR7E. it is a standard plug, for units with CDI ignition, has stock specs. If the plug you are running now is a little bit dark in color on the electrodes, then go with a BKR6E.
The BKR7E (V-Power)
the no gap thing is mostly for Iridiums since the tip is very small...but on a standard plug with a regular electrode I see no problem..I dont use the disk type gappers...I use a feeler guage with the gapper on the side just using the ground electrode ...the disk gappers are not that good..your touching electrode an ground electrode at same time possibly damaging the tip....the disk type is used to pry the gap open...
Discussion Starter · #15 ·
Thank you guys.
Discussion Starter · #16 ·
I guess I should have been more specific. In this chart it lists several NGK plugs. Which is best
Champion RC7YC - Alternative spark plugs
The BKR7E (V-Power)...... But I still think I'd use an Iridium = BKR7EIX :D
I have all the plastics off it now so it shouldn't be too bad.
Sure....... Cheater! :suspect:
Well I did it yesterday. Had pull the fuel tank. Just enough to get it out of the way. So to change plugs you have to pull all the front plastics, clutch vent and fuel tank. WOW
1 - 16 of 16 Posts
