Going to post this here because I'm not sure if I'll get a hit in the Repair/maintenance section.
I broke the spark plug wire connector. Can I just replace the connector, or do I need to spring for the $85 coil/wire asm?
I did the same thing, it's a easy fix. Pull the boot back , use a pair of wire strippers and cut a small piece of the insulation back. Reattach the wire clip and push the boot back . Wipe the inside of the boot with dielectric grease, and your good to go. Unless I totally got what your asking wrong. :)
EXACTLY what I was hoping to hear.
As long as you have enough cable,......you are good to go with a new connector and boot.
yeah... can I relocate the coil of is that a no no? I need about 1/2" ERG!
Should not be a problem.......
