1 - 10 of 10 Posts
Okay here is how you find it. Take your right hand and put it straight out and pretend you are hitch hiking. The thing that is sticking out on the end of your hand is called a thumb and when used correctly with the throttle lever will limit or increase your speed. :)
LMAO!!
2013 850ho
really funny. might expect such from a canadian .
But really, Is the limiter incororated in the CDI on this model ?
theres also a limit stop under the throttle that u can set, to only let you push it so far on those older bikes....
1 - 10 of 10 Posts
