06 800 sportsman 13k kms. No needle or odometer on speedo. Everything else works 4wd,tach,lights, there is 10 volts on 2 pins of the 3 pin conn at the back of the pod. Speedo or sensor. Jim
Thanks for your reply. I downloaded a polaris manual $8 and it shows the same thing, I had tried cleaning the sensor so new hall sensor is on the way thanks again.
when the speedo and odometer dont work and every thing else does..its most likely the sensor....to bad it was not just mud caked and cleaned up an worked....
