Good Day Evryone,
I have a questions regarding my 850. I bought it used. it had 28" tire on it. resently I down graded the tire size to 27" and sience then my bike is wild. If I'm stoped and give it full gaz on predy mutch any surface including grass. It pop right out on a welly. Is this normal? If I drive at arond 10 mph and go over a hum and give it good amount of gas it pop on a welly as well.
Over the weekend I took a look at the belt and notice that the spring in the lower clutch is Pupple.
The questions: What color is the stock spring?
How can i know if I have a stuck clutch or not?
Purple is the stock spring
These are the components of a aftermarket clutch upgrade. Not only is the spring changed but the weights are also changed. But just so you know an 850 has plenty of power to wheelie when you want to wheelie it.
Thanks this anwser evrything I wanted to know. I love my bike more with the 27" bighorn then the 28" mega mayen. Completely different animal.
This is the OEM stock spring and weights
