I was riding my 1000 today and I turned it off after riding and went to restart it after about 5 min and it started idling funny like it was tryimg to take off like u was trying to take off and then it died and I barely got it started back and when I did it was like in neutral and rev high rpm before it woukd go anywhere and would only go like 5mph and I limped it two miles back to the truck and when I get it home it started fine and run as normal again? I run it like 8 or 10 miles when I got it unloaded with no problem at all? It has been doing the weird idle thing for awhile ever since I put the fuel controller on it but not sure the problem is there any ideas?
Yes when the voltage regulator isn’t working, your battery’s not charging and then your fans not working and thennnn....limp mode. Check your charging system!
I would unhook the fuel controller and see how it does.
I agree with flyboy. If its been acting funny since putting the controller on, then it sounds like something about the controller isn't agreeing with the machine.
What brand/model controller is it?
