1 - 1 of 1 Posts
So the piston rod messed up and locked up the motor. Replaced that put everything back together. Corrected the timing and adjusted the valves. Now the check engine light is on and that trips a rev limiter it seems and I can’t get this thing to turn off. Checked the oil, fires right up and idles great. Just can’t get that light to go off so that it will run right. Any ideas?
polaris 110 efi
1 - 1 of 1 Posts
