Looking for wiring diagram
Have no spark
Was kinda week spark before
Loaded it up fine got to the location and reversed out of truck and stalled now has no spark .
Checked all connections seem all good
The shop i have been using said they don't suggest aftermarket coil/stator parts . But i have heard 2002-2004 600-700s had Ducati part problems .
So any suggested test would be helpful .
Not really down to just fire the parts gun at it .
I have the same bike with the same problem.
Dealer told me it was the a bad CDI Box, which is a Ducati part. Doing some research on here and other sites it is best just to do the ignition system retrofit that Polaris recommends.
I have not done it yet, but others say it will improve the performance of you machine.
The part number from Polaris is 2202603. Cheapcyle parts has it for around 450 dollars. The dealer quotes 3.5 hours to have it installed.
I will fix mine in the spring, no use this winter for it and do not want to spend 450 2 weeks before christmas!
Good Luck I hope this helps, keep us informed with what you do.
