every time i go into reverse the engine dies ,unless i push the over ride button.from what i read about this isnt it go to reduced power when in reverse?if so is tied into the electric throtal?or how is this wired in to the engine.
Welcome to the board!
The motor should not die. When you put the machine in reverse it limits the machine to 5 mph, anything over that speed the machine retards the timing unless the override button is pushed.
So maybe it is retarding too much and thats why it dies?is it the cdi box or is there another type controller?does someone have a wiring book with a digrame?
I have the same issue
Any fix yet for this? My 94 Sportsman 400L Dies in reverse unless the OD switch is pressed. Pretty Annoying!
