1 - 8 of 8 Posts
Hello everyone! My first brand new quad I bought last February its a 2013 sportsman 400. I love the thing so far. Around July I noticed a slight coolant smell and also noticed my resivor was always empty after I would ride and would have to fill it up every now and again. Well a couple weeks ago I was riding in the snow and the exhaust started steaming. I figured it was just snow. When I got underneath I noticed a green color and stuck my finger in it and it deffinetly tasted like antifreeze. So the coolant is either leaking from the manifold gasket? Or I noticed right above the exhaust there is a hole that was damp, weep hole? Doesn't drip on the garage floor and the oil is normal. Any help would be appreciated!
Thanks jeremy
2007 500x2 le
Is it under warrenty ?? If so dealer would be the first place it should go other wise would you be able to post a pic ?? Don't think the exhaust manifold should be leaking antifreeze possible a head gasket is seeping ...and dripping on to your exhaust??
Thanks Shane, not under warranty that with my luck ran out in July :(. But yes that's what its doing once its warm leaking on to exhaust and burning either from around the gasket or like I said there's a hole right above the exhaust. not sure if you know the hole I'm talking about or not I assumed it was a weep hole. I can get a picture after work
Hi Shane got a pretty good pic of the leak
for you to see. Would you be able to tell me how to post it for you to see off my phone?
Welcome to the board!
2007 500x2 le
I should be able to hit the reply button scroll down click manage attachments . Should bring you to another page then click choose file should do it ! Sorry for the late reply budd
Thanks Bruce for the welcome! Seems like a pretty good place.
Shane I couldn't get it to let me set the picture in this post for some reason but managed to set it as my profile picture? Lol. But anyway I think if you click on my name it will take you to my gallery and you can see it. If you have time check it out thanks a lot so far!
1 - 8 of 8 Posts
