Having trouble after starting ATV as soon as you let go of throttle it stalls, sometimes backfires. It almost sounds like it's not idling right. Any suggestions before I take it to a dealer?
ETC probably needs adjusting. Do you have an eighth of an inch of freeplay in the throttle at idle?
ETC is adjusted by the thing under the rubber cover on the throttle cable, about 6 inches from the throttle housing.
Sean
Welcome to the board!
NP, glad it worked out for you.
Sean
