Hi all
I have a 2001 Sportsman 500 6x6 needing a gearbox overhaul. Low gear whines pretty loud under load and it jumps out of hi gear constantly.
I need to have it out of action for as little time as possible and parts take more than a week to reach my location so I'm going to preorder those parts most likely to need replacement in the hope I can get the rebuild done in a day or so.
Can anyone offer tips on what parts are most likely to need replacing? Shift forks and dog gears seem likely.
Cheers
Damien
Welcome to the board!
That's kinda what i thought , when i did mine. I found very little wear on the gears and hardly any on the shift forks.
Your trans. has two silent chains, be sure to get the short chain as well as i am sure it all stretched out. this effects it staying in gear.
After you get it back together and back in , you'll need to readjust your linkage, to where it is supposed to be.
