Hello, I got a 2005 Sportsman 500 HO that I’ve been messing around with trying to get running for awhile now. It had real bad rod knock so I replaced the crank now when reassembling, the starter won’t spin. I checked the voltage at the starter motor when the key is turned and i’m reading 13.1V( Because I have it hooked up to a jump). Not sure why it won’t spin if I’m getting voltage. I clamped the jump straight to the stud on the starter motor and it spins then
