I have a 2008 500 EFI that will not turn over . I do not hear the normal EFI sound when turning key to start. On the gauges everything is there except for the transmission gear designation. I checked fuses in front of handlebars everything looked fine. Headlights are super bright and battery has been on a maintainer. Kill switch is in the on position Help
Hold the brake lever and try to start?
BUMP for ranger
Sorry I can't be much help i'm not familiar AT ALL with the EFI Machines. EFI is nice when it works but when it doesn't it can be a B****. Some other members on here know those machines like the back of their hands and will chime in and help you get it figured out. Good Luck !!!
Start tracing wires, start at battery, make sure connections are clean and tight, go to solenoid, remove wires , check nuts under battery cables for tightness, if not there look in black pouch, this is a circuit breaker, they get corroded.
