yep on the list
I figure,it runs super sounds great etc etc. just that fan staying on was weird to me. So I started thinking of things I have to check and started the cheapest first,like the little green cap in the overflow bottle,i'll take out of my other sportsman,(with 300 miles on it) while I do my actual "temp" test throughout its starting,till the fan comes on, till it is shut off then turn key back on for the fan to finish its cycle till it shuts down. (the only time it shuts down"the fan" is after the 4 wheeler is shut off) then when I turn the key back on which is habbit...(on hot days) for the wheeler to finish cooling,where they are so closed in. But im going to document every change in temp from start to finish. will be back with results today,check back if you can later this evening ,Id like anyones input after having numbers,I know would help,I mean it would help myself if I knew,I was a mechanic for over 10 years till I couldnt do it anymore with my C.O.P.D./Emphazima I mean i still do everything I can phisically do,but not under a time limit,and sometimes with oxygen,so it sucks,like I did all the matinence on this 4 wheeler when it cam in ,the guy I got it from did his "yeah my guy went right through it" I knew better,but checked it over well to make sure it was clean and as sound as possible,then brought it home,went from top to bottom,oil,EVERY grease fitting..,did all fluids most people dont bother with,like hub oil,front and rear case fluids,all with polaris oils to spec. As I said with my condition I cant walk far distances so a break down for some dumb reason isnt a good thing,thats why I use just my newest one away from home right now,and want to be sure this one Im doing now is done before hunting seasons,and even the newer one with no miles on it barely Im not taking out in the woods to far away cause the selonoid went on the winch...it just dont end,but they are super when they work right
THANKS again guys
