I have a 1999 sportsman 500. I purchased not running, was told it needed a stator, replaced stator, pickup coil, ignition coil, ignition switch, spark plug and disconnected speedo as some on here suggested on other threads. the stator was full of water when I pulled it out, flywheel magnets still strong. What I get is bright blue spark as I turn off the ignition switch. it will give me a bright arc everytime as the switch is killed and that is the only time so I replaced the ignition thinking maybe was problem but not. I did try my friends CDI his is same and made no difference either . Does this make sense to anyone? Any help or ideas would be appritiated. Thanks Adam
