1 - 8 of 8 Posts
I recently purchased a 2008 sportsman 500ho. A couple of weeks ago the fan began to blow continuously and the hot engine notification came on immediately after start up. I replaced the temp sensor but that didn't fix the problem. From what I have read, its most likely the ECM that needs replaced.
Question - if I replace the ECM, do I have to have it programed at a dealer or is it simply a plug and play fix?
to the forum
Your question has now been logged into the queue and the next available forum member will answer you shortly. You will be given more advice than you could hope for.
The real shortage in this country is common sense.
Make sure the radaitor is not plugged with mus restricting the air flow
Depends on which unit you are calling an ECM?
Most likely the controller module (part number 4011568 @ $525)
153355
This unit is plug and play - if it was EFI, it may have required programming
1 - 8 of 8 Posts
