Decided, what the hell, why not. I have a K&N air filter with the pre-filter wrapped around it, no mod to the snorkel or intake.
Just took a 2'5" hole saw and cut a hole in the end of the muffler. I left the little stock outlet that hangs down, intact. Figured it could act as a drain hose if I spray any water into the muffler.
I didn't like how it looked with just a hole in the end, and I happened to have a short piece of 2.5" diameter exhaust tubing sitting on my workbench from another project, so I installed that in the hole. It was hard to force in there(giggity), and had to work it in and hammer it in, but it seemed like it was not going anywhere. I don't have a welder, but I got some hi-temp JB weld and sealed it up, and then painted it with matte black header spray paint rated for 1500 degrees.
Sounds mean, aggressive, etc... I think that just opening the muffler up a tad won't throw off fueling too much without any intake mods, and perhaps the FI will compensate. The exhaust smells rich enough, but time will tell when I get out and ride it. If it seems like it has any issues I can get a fuel box to richen things up, but with just the hole in the end and it still having to exhaust through that inner 1" baffle, I don't think it will make too much of a difference.
Anyway, here are some pics, almost looks stock and once it is covered in mud and dirt you won't think twice looking at it. But it sounds pretty good, I think. A camera phone recording will only give you so much sound quality for this stuff, but it gives you an idea...
