Hello, I have a 2004 sportsman 700. Last season the 4wd worked fine. I only ride 2 or 3 times a year and its easy riding. I replaced the battery this winter and have not riden since i replaced the battery. I got out for the first time in 6 months to plow the driveway and now it does not engage. The speedo works, awd lights up, reverse over ride works, everything works as normal other than the front tires wont spin. I read maybe front diff fluid needs changed? Is there anything else thats common on these to check first? Thanks
