Is there any routine maintenance or lubrication to do on the Sportsman 700 clutch? It's working fine and the belt looks new. I just want to know if I should clean or lube anything before I close it up. I searched, and couldn't find anything specific.
No lube! Check rollers on both clutches of it has ebs, buttons in secondary if it does not. Check weights in primary to see that the move freely and don't have much of any side to side play in them. Bushings in both clutches for excessive play. A service manual will give you all the specs.
Thanks. I didn't think there was any lube requirement. It all seems to be in good shape.
