1 - 1 of 1 Posts
2007 sportsman 700 efi
I bought a couple used rear axles off eBay. Suppose to be matching set of rear axles. I believe guy screwed up because the outter diameter of one of the axleS right behind the outter splines is about .400" difference. My question has to do with the cup that goes into the rear diff.
My current cups have no retaining ring holding the cages and balls in the cup. The one different axle he sent me, the cup has a large retaining ring holding the cage and balls from being pulled all the way out.
My question is can I use the cup with the retaining ring? Overall size of the cup and splines seem correct.
1 - 1 of 1 Posts
