I have the sportsman 800 -06 and it seams that the rear foot break can not maintain the pressure when it has not been used for a while and it cant break at all. But the front break still work, even the rearbreak when you break with front. Why?? I´v heard that even the -09s still has the same problem.
Thankfull for all answers
The swede!
it's a common problem, you can try to bleed that rear brake if it dont last you have to replace the master, that valve looking thing the petal is attached to. The reason your normal brake still works is because there are 2 seperate lines and chambers in te caliper, one brake systemm fail's you have a backup.
Welcome to the board!
