Thanks! Exactly what I wanted to see before I order.offset should be 4+3. im running 2.0's on 14" itp beads at 4+3 offset. @ 5psi im getting 13.5" of clearance at the floorboards and front n rear belly skids. I think its the perfect balance of clearance and center of gravity. my bike is very stable, great wheel and tire combo.
I haven't bought any rims or tires yet.If you have the HD1 beadlocks then you have a 4+3 offset which would make these tires fit ..the stock wheel offset will be a tuff call....I believe the stock is 6+1..which may cause rubbing on tie rod ends...
