Sportsman 800 EFI HO Instrument Panel
2K views 3 replies 2 participants last post by  bp405
Hey Guys, first post here. I have a couple problems with the instrument panel on my 08 Sportsman. First, the "wrench" icon won't go off. I went to the owner's manual and followed all the steps to get rid of it, but it continues to be lit up every time I start it.
Second, the fuel gauge is acting crazy. Out of seven or eight LCD segments indicating the amount of fuel, only the first two or three from the bottom will light up, even when the fuel is filled all the way up to the filler neck in the tank.
Any ideas on either or both of these problems???
Thanks in advance...
#2 ·
Check the harness that comes up into the pod. The constant twisting and turning of the wires causes them to either break or become exposed.
#4 ·
No problem. Post back if the harness isn't the fix and we'll figure it out.
