I have a 2005 Sportsman 800 that I bought used about a year ago. I have been working out the bugs and getting it back up to a happy healthy status. It's getting good now. The previous owner had the headlights modified somehow so that all three lights are on all the time, whenever the headlight switch is turned on. Not sure how it was wired, but I do plan to dig in a check it out. Recently out hunting in the evening, I did have the lights on most of the time we were riding. More than any other times I had been using the ATV. This time, the headlight bub in the center pod, got so hot it melted the large headlight housing. The back reflector area was toasted. I ordered a new housing for $100 from my local Polaris dealer and installed it yesterday. I have not yet wired up the bulb as I fear it will melt the housing again. Yesterday evening out hunting I just used the 2 regular lower headlights.
Has anyone experienced this, or heard of this happening? I suspect there is some ******* hillbilly wiring going on. Maybe direct full amperage off the battery or alternator or something? The wiring harness looks fine. No heat damage that I can see so far. Just the housing.
Keith
For fun, here it is:
The 3 to 1 headlight mod is super common. That is not really something out of the ordinary.
Check for a small relay that is installed in the pod.. Might be installed between hi headlight wires
i just put 50 watt bulbs in all three of my lights but dont run all three all the time
I wasn't aware that they made anything higher than a 55 watt 800 series bulb, 50W is already factory so I don't see an extra 5 melting a housing.
