1 - 8 of 8 Posts
· Registered
I have a 2009 sportsman 850xp that was boring alot of oil towards the end. It inevitably sheerd the cam sprocket pin and bent valves. I was going to hone and replace the rings , then everything on the way back out but in the service manual it says not to hone cylander when replacing rings.... so now what?😳
· Premium Member
Font Line Window Pattern Screenshot
to the forum
Ball Gas Font Vehicle registration plate Automotive lighting
· Administrator
The cylinders are plated with a composite material and you can hone them if you want to, but the composite material (silicon/boron/carbide and other metals) is so hard that a typical glaze breaker or rigid hone hone will not impact the coating. From the pictures it appears the composite coating is worn through at the top of the cylinders. I suggest if rebuilding, to sent the cylinders along with the new pistons to a cylinder plating service to have the cylinders renewed and sized correctly to the new pistons.
It is recommended when servicing a plated cylinder engine that the cylinders not be honed when installing new pistons and rings as it is simply a waste of time, however, just to clean the cylinder prior to installation of new pistons and rings, using a green scratchy pad (Scotch Brite) to remove dirt and carbon.
1 - 8 of 8 Posts
