On to recent developments!
Rigid Industries Dually is one of the best priced upgrades from bargain basement no-name Chinesium LEDs. Regularly found on Amazon for around 130ish, these will more than likely change your mind on budget LEDs. 1536 lumens each, these put out more light than a single 22" MicTuning LED bar.
In Coach's words from Letterkenny, cheap lightbar output is "F*#/ng embarrassing!" True lumen ratings are a really good thing.
Had to repaint the bezels after swapping them from the truck.
Fitting the 2" clamp mounts on the bar is challenging since you have to open the clamps so wide, as well as drill out the mount tabs for the 5/16" cap bolts Rigid uses.
Hardware is super tucked away. Have to put the brackets on without the light due to lack of space, then add the light after to align, then remove again to tighten everything
Tucked back behind the bar for impact protection, as well as behind as much of the winch cable zone for angled pulls as possible.
They recess pretty well, despite being fairly bulky for a 4 diode pod. The Baja Designs Squadrons are positively svelte in comparison.
Didn't impede access to the clutch, which is, well, clutch. Even a thick gloved hand should be able to freespool and lock
Wiring goes right behind the winch mount, there are access holes perfect for a clean wiring layout.
