Hello!
i did a diagnostic check on my Polaris Sportsman efi -2006 because it has a charging problem but i cant understand the codes?
Should i count the blinks or what? Can anyone tell me?
I recorded it so here is the youtube
it tells you in your book what to do. I can't remember for sure but will look for you if you don't have a book.
Dealer told me if you don't have an accurate reading when looking at your r.p.m. it's a pretty good sign your stator is toast. I had mine replaced.
Yeah tanks. The codes are 12 22 47.61
12 is just the start code and 61 is the end code, so 22 and 47 is the problem. i disconnected thw negative from battery and code 22 is no loger active, just 47!?
And that is a IAC problem...what is that?
I think it is the wiring harness for the throttle body. Sometimes these wires rattle loose. take it apart and check them.
