1 - 10 of 10 Posts
is it possible to run a 2006 sportsman 500 efi without a battery or is their a mod that will allow this ?
I will venture to say no. You need it to run the pdm. Besides without a battery you can easily blow up all the electronics, bulbs and stuff with an overcharge situation. The battery acts as a reservoir for extra voltage the stator produces. Best get yourself a battery.
^What he said. If you have EFI and not enough/no battery, your dead in the water.
Curious. Why wouldn't you want to run it with a battery??
And like stated above, battery is a critical element for the electrical system.
Efi
i'm not trying to run without a battery, i was trying to figure out if the battery went dead while on a long ride what options would i have . i guess i would be walkin.
If you have a recoil starter, even if the battery is too low to crank it, you'd probably be able to get it started. But as stated previously I wouldn't run it without battery installed, and that's a moot point since you said that's not your intention.
This. Gotta have a battery in it or bigger issues on the horizon
Discussion Starter · #9 ·
Efi
THANKS TO ALL, ASKED AND ANSWERED. I PUT IN A NEW AGM BATTERY JUST TO BE ON THE SAFE SIDE.:veryhappy:
Lol! Yes, not good to have a dead batt on the trails. I keep jumper cables in my box and always keep my battery on a tender.
1 - 10 of 10 Posts
