Follow the shift linkage down toward the rear of the foot well you can see bell crank on the end of the shift rod that came from the front, the bell crank attaches to the rod ,goes through a bushing and attaches to the shift gears, there should be an electrical connection there as well which is your gear position sensor. The gears that wear are behind this small plate I think it has 6 small bolts to hold it on, also on the side is your detent hold pin it has a spring that runs to your foot brake. I think if you're having a bit of trouble knowing if you have a H-shift pattern or an inline this may be a problem for you.
