I am sure as many of you know the rear cargo box from the Sportsman Classic fits also on the XP. The only issue I have found (as well as one other I have talked too) is that sometimes when you are on a really bumpy trail the rear box becomes loose. Other than using a bungee cord has anyone found a fix for this? I my self have thought of cutting of the rear plastic pins that go into the rear part of the rack but am not sure there is enough space on the inner part of the box for the lock and ride mount to fit?
Did you tighten the nuts on the rubber anchor?
Yes I also added spaces to the rubber would be lower like on the front box. I think its because these boxes have metal L brackets on the side that give when in bumpy trials.
yea i agree with ya. :banghead:
