Hey guys, I bought a used 2006 sportsman 450 last summer, and almost imediately I noticed when putting it in reverse, going uphill it stalls out. It's like it's starving for gas, if I keep my finger on the throttle it will die out. BTW it seems to be a very high speed reverse, which I really don't like. When I put it in high range going uphill, I dont have the same problen as reverse uphill...it performs fine. Also, when moving forward, it almost always has a split second of hesitation-but when it does grab hold-it's off to the races! The only thing I've done so far is changed the soleniod and the spark plug. Any help is appreciated.
Let's separate this into two questions.
Reverse Issue:
I wonder if the reverse override is causing interference? Have you checked those electrical connections?
Clutch engagement:
Have you ridden another Polaris to see if the engagement is similar or more harsh? Is the engagement of the belt causing any noise from the belt?
Discussion Starter #3 (Edited)
Sorry, I don't know alot about ATV's, nor do I know what reverse overide is, or what it's purpose is. Maybe someone can enlighten me. :gruebel:
And no, I don't know of anyone else with a Polaris. Would a problem clutch only show it's ugly head while reversing? It's confusing...I just don't understand why the engine would bog down to the point of stopping completely.
Without holding the yellow button it won't let you rev too high and won't go into 4wd while in reverse.
Sean
