I bought a used 2015 sportsman EXT to plow snow. It starts easy and idles when cold. Runs good until I plow snow. After the 1st pass when I let off the throttle it stalls and will not start or idle unless I give it gas, as soon as I let off the gas it stalls again. If I let it sit for 5 min. it will start and idle like it should. Any help would be appreciated.
Check the ETC contacts in the throttle housing. Could be too tight in there. I would also check the charging system and battery. The charging systems on these machines doesn't supply charge at idle. Plowing is not enough RPM for long enough so if you have a weak battery it could be part of the problem.
