1 - 14 of 14 Posts
hey guys 2019 sportsman 570 25 hours just changed my gearcase oil and now when I shift into gear it makes a clunk. No clunks when driving only took it around the block. Drained oil till no drips on level ground and then filled to threads was just under a quart. Is the level too full or not full enough doesn't make sense? What causing this new noise? Thanks for any input
140692
No idea about the clunk, but it may be normal if it just clunks once when going into gear.
Ok thanks my only thougjts are it did not clunk before the fluid change so why now?
Unknown to me. Idle speed too high? Too light of oil in the transmission? Problem with the belt or clutches?
If it only clunks when going into gear, I'd call it normal - maybe one of the other 570 owners will chime in.
2015 Sportsman XP 1000 LE Touring
Reactions: sbla
I would have been worried too, but it clunks and chunks like my 99 sportsman does with the same mileage!
Discussion Starter #10
lol I'm slowing figuring out the individual quirks in these machines love to ride it but shes temperamental
1 - 14 of 14 Posts
