Been having issues for a long time on my 2010 XP with fuel level indications. It would stop reading when about 2/3 full.
I read on here about others having similar issues.
I pulled the pump assembly out and took the float arm partly off the pump assembly. I tweaked the wiper arm down to make better contact.
This has been bugging me for a long time, I'm glad I fixed it.
Not too hard to do but the tank has moved over so the pump can lift out. It took me about 2-3 hours which included rinsing the dirt away from the pump prior to disassembly and adding/draining fuel to verify proper operation.
I fixed an issue in mine but removing the fuel pump and making sure it is indexed properly to the mark on the tank. I think it may have moved a bit and the float was touching something inside. It has worked since. Took only about a half hour and a big ass pair of slip lock pliers.
Same here. I had to re-index it after I re-insalled it.
I could have been faster I guess but it was Sunday lol.
I'm glad I didn't have to replace it.
