21 - 40 of 46 Posts
Compared to mine, does yours lean?
MrEd, how does my rear end look?
Reactions: pcaster
I think I need to make mine ride a little stiffer and tires sit straighter when parked . Do I have to jack up the wheel to adjust it and is this a wrench that does it.?
( borrowed wrench, guy said it should be it. lol )
I've been using the shock spanner below for years with a 3/8 ratchet or if they're old and rusty I use a 10" 3/8 breaker bar. Makes shock adjustment easy.
You don't need to jack the machine all the way off the ground. Just lift it enough to get the weight off the shock spring.
150980
2017 Sportsman 850SP
Thanks MrEd. Yours look pretty bad a$$ as well. One day we’ll compare at HMT 😉
Reactions: MrEd
Is mine level? In all fairness the garage floot slopes downwards from back to front....
Reactions: Gmartino100
21 - 40 of 46 Posts
